Hello,
I had installed the Automox Agent on some of our Windows Server vms but it shoes Not Compatiable. Any thoughts on this?
Hello,
Hello
I have checked on all the vms and they have sufficient disk spaces.
I think I found the issue, maybe it is our network something is blocking it. It shows Server Unreachable.
Drill into one of them and click the following. it should tell you why it is not compatible
Hello,
If you are unable to determine the reason for the devices showing as incompatible by using the Compatibility Checklist, then please open a support ticket through our Customer Portal so an engineer can assist.
Cheers,
Brandon
