Hello @MRaybone
When Patching Linux you don't really need to do anything special, patch policies are not OS specific so any patch policy will patch Linux unless you have a patch advanced and have specific requirements using that.
Some other things to watch for are the reboots, not every patch requires an OS reboot. Usually anything kernel related will need a reboot.
Example:
dbus
*-firmware-*
glibc
gnutls
kernel-*
hal
openssl-libs
systemd
udev
I’m glad you mentioned the kernel. We’re in a position where we can’t upgrade the kernel kwaves at CrowdStrike], are those all the packages we’d need to filter out in order to keep the kernel version the same?
