Hello!
I have a worklet that has been running weekly for months with no issue, the worklet essentially grabs patching logs from each device in Automox and exports them all to a CSV. I noticed on around January 18th of 2022 that the script started reporting nothing so I ran the code locally and am getting an error:
Invoke-RestMethod : The request was aborted: Could not create SSL/TLS secure channel.
At line:11 char:13
+ $response = Invoke-RestMethod $apiUrl -Method 'GET' -Headers $headers ...
+ CategoryInfo : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-RestMethod], WebExc
eption
+ FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeRestMethodCommand
I know Automox has the limitation of no more than 500 results when pulling from the API, but I am well under half that. Here is the full script for context:
#Set Execution policy to allow for 3rd party modules
Set-ExecutionPolicy Unrestricted -Force
#Define API Key and URL to get initial Machine list
$apiKey = "APIKEY"
$apiUrl = "https://console.automox.com/api/servers/"
#$headers.Add("Cookie", "ax_session=CENSORED")
$response = Invoke-RestMethod $apiUrl -Method 'GET' -Headers $headers -Body $body
$response | ConvertTo-Json
$time = (Get-Date).ToString("yyyy-MM-dd-HH")
Export-Csv "C:\Automox_Patch_Exports\Patch_Export_$((Get-Date).ToString("yyyy-MM-dd-HH")).csv" -NoTypeInformation
$name = $server.name;
#For each machine get the patch info according to machine ID and Org.
foreach($server in $response){
#Define Server ID, Org ID, and Group ID.
$id = $server.id
$organization_id = $server.organization_id
$server_group_id = $server.server_group_id
$apiUrl = "https://console.automox.com/api/servers/$($id)/packages?o=$($organization_id)"
#Define which objects you want to be included in the CSV. See (Under "Response") for full list: https://docs.automox.com/api/endpoints/list-software-packages-for-a-device
$DesiredProperties = $response | Select-Object $server.name, installed, create_time, display_name, package_id, software_id, cve_score
#Add the information to the CSV.
$DesiredProperties | ConvertTo-Csv -NoTypeInformation | Add-Content -Path "C:\Automox_Patch_Exports\Patch_Export_$time.csv"
Tried researching the specific error, but was not able to come up with much so wanted to check with Automox while I kept troubleshooting on my own.
Thanks in advance for any tips :)
Best answer by JHagstrom
View original
