Solved
Proper way to install using EXE
  • 23 September 2022
  • 2 replies
  • 180 views
I am trying to install the Barracuda Content Shield for our endpoints but its an EXE and not an MSI, plus it needs a key file. The instruction on their site say to use this on the command line:
BarracudaContentShieldSetup-2.3.4.1.exe
ISFeatureInstall="WebFiltering,MalwarePrevention"
KEYPATH="bcs.key"
/silent
Can i upload both the exe and .key file in a policy? Also, for the command line in the policy it says to use powershell syntax and I am not sure how to convert the above to powershell.
Thank you.
icon
Best answer by jack.smith 24 September 2022, 01:14
View original
Userlevel 4
Upload both files to the worklet. Then give this one-liner a try
Start-Process BarracudaContentShieldSetup-2.3.4.1.exe -ArgumentList "ISFeatureInstall='WebFiltering,MalwarePrevention' KEYPATH='bcs.key' /silent" -Wait
Thank you. I tweaked what you put just a little bit based on some other worklets i saw. It works. Thank you.
exit (Start-Process BarracudaContentShieldSetup-2.3.4.1.exe -ArgumentList ("ISFeatureInstall=Webfiltering,MalwarePrevention KEYPATH=bcs.key /silent") -Wait -Passthru).ExitCode
