This worklet will disconnect all mapped drives specified by $removeDrives in the evaluation and remediation. Be sure to set $removeDrives identically in both. The drives will not appear disconnected until after a reboot. Details of the user and drives disconnected will appear in the activity log.
Evaluation:
.SYNOPSIS
Delete Specified Mapped Drives for All Users on a System
OS Support: Windows 7 and above
Powershell: 2.0 and above
Run Type: Evaluation
.DESCRIPTION
This worklet is designed to search for any mapped drives specified with $remoteDrives, and disconnect them. If any setting is found to be non-compliant, the evaluation script will close with an
exit code of '1' to trigger remediation. $removeDrives needs to be set the same for evaluation and remediation to work correctly. If drives are found and disconnected, the drives will not appear disconnected until after a reboot.
To use this worklet, add the desired parameters to the $removeDrives line at the top of this script.
.NOTES
Author: twiese
Date: May 27, 2021
# Define mapped drives to disconnect
$removeDrives = @("Y","Z")
# Get User details including SID
$users = Get-WmiObject -Class Win32_UserAccount -Filter "LocalAccount = 'True'"
# Add HKEY_USERS to a PSDrive for easy access later
New-PSDrive -PSProvider Registry -Name HKU -Root HKEY_USERS -ErrorAction SilentlyContinue | Out-Null
# Loop through the list of users to check each for matching drives to disconnect and exit when first one is found
Foreach ($user in $users) {
# Retrieve SIDs for each user
$sid = $user.SID
$name = $user.Name
# Load Registries for users, if ntuser.dat exists
# this prevents us from attempting to load Administrator and similar accounts
if (Test-Path "C:\Users\$name\ntuser.dat") {
# Load user's ntuser.dat into the registry
& reg load "HKU\$sid" "C:\Users\$name\ntuser.dat" | Out-Null
# Get mapped drives for user and see if any match drives to be removed
$drives = (Get-ChildItem -Path HKU:\$sid\Network | Get-ItemProperty).PSChildName
$matches = $removeDrives | Where-Object { $drives -contains $_ }
# If any user has a matching drive, immediately clean-up PSDrive and exit for remediation without checking for further matches
If ($matches) {
Remove-PSDrive -Name HKU
Exit 1
# Clean-up the PSDrive if no results
Exit 0
Remediation:
.SYNOPSIS
Run Type: Remediation
.DESCRIPTION
.NOTES
Author: twiese
Date: May 27, 2021
# Get Users details including SID
$sid = $user.SID
$name = $user.Name
If (Test-Path "C:\Users\$name\ntuser.dat") {
# If any mapped drives match ones to be disconnected, disconnect them
If ($matches) {
ForEach ($match in $matches) {
Try {
Remove-Item "HKU:\$sid\Network\$match"
Write-Output "User: $name, drive $match disconnected. "
} Catch {
Write-Output "User: $name, drive $match couldn't be disconnected. "
