Has anyone put together a working approach for doing this via Automox? I’ve got Windows 10 machines deployed with Office 365 Pro Plus in 32-bit, and I would like to move that to 64-bit.
I understand the general approach is to uninstall all traces of Office 32-bit and then reinstall Office 64-bit. I also know you cannot mix Office 64-bit with Visio/Project 32bit (and Visio / Project are not in the suite of apps for Office). So I’m willing to ignore those machines and handle them manually.
I’ve also done some research into this https://psappdeploytoolkit.com/ that looks like it will do the trick. However, I have concerns about having this running in the user-context so that UI prompts are interactive.
Basically I’m looking to save a ton of work if someone has already built an approach for doing this.
