Error from performRequest("install", body)
srheins
September 28, 2021 at 5:39 pm UTC
I was re-installing the Automox agent on a device where it had been removed, and now I get the error below in the log:
Error from performRequest(“install”, body): Post https://api.automox.com/install: dial tcp 44.236.226.107:443: connectex: No connection could be made because the target machine actively refused it.
2021/09/28 10:25:46 main.go:370: ERROR: client.DoInstall(): Post https://api.automox.com/install: dial tcp 44.236.226.107:443: connectex: No connection could be made because the target machine actively refused it.
Has anyone else experienced this before?
Replies (4)
BrittanySeptember 29, 2021
Just checked with support and they said it was a firewall issue, hope that helps!
AnonymousSeptember 29, 2021
👆 Came here to suggest this. 😉
srheinsSeptember 29, 2021
#3
Thanks for the help. I’m in the process of waiting for our network engineer to re-configure the firewall in our lab.
#4
Yeah, if the fw does any kind of content filtering or IDS/IPS, you might need to whitelist us.
