Is there a way to automatically remove stale clients after a set time? I would love to have the ability to automatically remove devices that have not been online for a duration of time such as 60 days.
Hi Jay,
Thanks for your question! While Automox does not have any automation directly in the console to remove disconnected devices, we do have a guide on how to simplify the process on demand.
You can sort your devices on the Devices page by “Disconnected For” and then mass select anything older than 60 days, then choose “Remove Device” from the bulk actions dropdown. Otherwise the script mentioned in the link below can help with a scripting version.
Check out our guide in the Knowledge Base via the Customer Portal:
https://help.automox.com/hc/en-us/articles/5351996773012-Disconnected-Devices-Cleanup-Using-the-Console-or-PowerShell-or-Python
Cheers,
Brandon
Login to the community
