Worklet to install Arduino IDE
I just wanted to share an example of getting creative with installs. This software will require a user prompt to install the certificates, but if they are already installed, you can install it silently. So I installed the software on a workstation manually and exported the certs. I added them to the policy package and use powershell to install the certs before installing the software.
#REQUIRES -Version 2.0
.SYNOPSIS
    This script allows an admin to install Arduino IDE.
.DESCRIPTION
#Handle Exit codes:
trap {  $host.ui.WriteErrorLine($_.Exception); exit 90 }
function Arduino{
    #############Change the settings in this block#######################
    Try {
       certutil -addstore TrustedPublisher ArdruinoLLC.cer
       certutil -addstore TrustedPublisher ArdruinoSRL.cer
       certutil -addstore TrustedPublisher adafruit.cer
       Start-Process -FilePath "arduino-1.8.16-windows.exe" -ArgumentList "/S" -Wait
    Catch {
        exit 1
Arduino
Thanks, David!
