Worklet: Get-IPConfigurations
   ______     __        ________  ______            _____                        __  _
  / ____/__  / /_      /  _/ __ \/ ____/___  ____  / __(_)___ ___  ___________ _/ /_(_)___  ____
 / / __/ _ \/ __/_____ / // /_/ / /   / __ \/ __ \/ /_/ / __ `/ / / / ___/ __ `/ __/ / __ \/ __ \
/ /_/ /  __/ /_/_____// // ____/ /___/ /_/ / / / / __/ / /_/ / /_/ / /  / /_/ / /_/ / /_/ / / / /
\____/\___/\__/     /___/_/    \____/\____/_/ /_/_/ /_/\__, /\__,_/_/   \__,_/\__/_/\____/_/ /_/
                                                      /____/
https://github.com/bragdonjm/PS-Automox-Worklets/blob/main/Worklets/Get-IPConfiguration.ps1
Computer system sprawl is a real thing. Finding specific information about a system in some
easy to use automatic method can be tricky. Here is a worklet to grab detailed information about all
network interfaces on a remote windows system.
Note:
- Powershell is only.
- Verbose is supported though there is not much there.
Usage:
Example:  .\Get-IPConfiguration.ps1
ComputerName IPAddress    SubnetMask    DefaultGateway DNSServers   IsDHCPEnabled macAddress
redqueen     10.23.23.51  255.255.255.0 10.23.23.1     {10.23.23.1}          True 0C:9D:92:81:15:A1
redqueen     172.31.160.1 255.255.240.0                                     False 00:15:5D:89:AD:34
redqueen     172.20.32.1  255.255.240.0                                     False 00:15:5D:05:92:95
Faq:
Q: Why did you leave param in, but effectively blank?
A: No real great idea on what to put there that might be useful. It is left just so -verbose works.
Q: Why no JSON this time?
A: I don't foresee this being useful to hand data elsewhere. A human will probably read this.
