Worklet: Ensuring Firefox is installed on Mac devices
This worklet will evaluate Mac devices to ensure the latest version of Firefox is installed. If the worklet finds the Firefox applications is not installed, the remediation code will install it on the device.
Evaluation:
#!/bin/bash
#example script for installing Firefox on Mac devices
#evaluate the device to see if Firefox is currently installed.
if [ -d "/Applications/firefox.app" ]; then
else
        exit 1
fi
Remediation:
#!/bin/bash
#create a temporary directory to download Firefox install file
set -e
tempfile=$(mktemp)
#download the latest version of Firefox to the temp file
echo "Downloading Firefox..."
curl -L "https://download.mozilla.org/?product=firefox-latest&os=osx&lang=en-US" -o "$tempfile"
echo "Installing Firefox..."
#mount the firefox dmg file to a volume
hdiutil attach /tmp/Firefox.dmg
#copy the firefox app to the devices applications
cp -R /Volumes/Firefox/Firefox.app/ /Applications/Firefox.app
#remove tmp file and unmount the image from the volume
echo "Cleaning up..."
hdiutil detach /Volumes/Firefox/ -quiet
sleep 2
rm -f "$tempfile"
Two things caught my eye:
“Google firefox.app” looks wrong?
And the URL to get the most recent version of Firefox for OS X would be something like so: https://download.mozilla.org/?product=firefox-latest&os=osx&lang=en-US
It looks like Adam is pulling from their CDN directly, which might explain the different URL.
I think you’re right on the “Google firefox.app” - I’ll fix that to just say “firefox.app”
I typed that in by accident when adding comments. Please make the change.
Made the change
Thanks @awhitman!
This is correct, but I can update it to the Mozilla URL
I wonder if the CDN has a most recent URL too. I went by the instructions that I found on their FTP server. Old school.
https://ftp.mozilla.org/pub/firefox/releases/latest/README.txt
had issues curling the latest version URL. Direct pull from CDN and I will update the latest URL link
This is for the .exe which would work. Just need to change the syntax to run the .exe instead of mounting the .dmg to a volume.
It’s already live - people are getting to see the sausage made in real time :slight_smile:
This cURL command worked for me. But I did not try it in the sausage machine.
curl “https://download.mozilla.org/?product=firefox-latest&os=osx&lang=en-US” > “Firefox.dmg”
Worked for me too! Must have clicked the wrong link. Made the change and tested it. Should be good to go!
And that is how quickly we fix stuff at Automox :slight_smile:
Thanks for the speedy response guys!
Sudo isn’t required in this context as the agent runs as root user. It will actually change the environment if you use it here.
That curl command will return an HTML document as that address is a CDN so you need to follow links with curl -L <address>
hdiutil can return errors if that URL returns a bad value and may not error the way you like.
Shouldn’t the remediation script also return 1 or 0?
