Worklet: Add Shortcut to Web Application Specifying Which Browser to Use
This worklet as written adds a Chrome shortcut to the user’s desktop and start menu named “TSheets” which points to a web app. You can choose to only create the shortcut in one place or the other if you want. If you wish your app to be opened with a different browser, specify $BrowserPath to point to the installed browser you wish to use. The parameters in the remediation below describe how to set the variables.
Evaluation:
Exit 1
Remediation:
    .PARAMETER BrowserPath
        Location of the Google Chrome browser executable. Google Chrome needs to already be installed for this script to work.  If you wish for a different browser to execute the Web App, alter $BrowserPath
    .PARAMETER ShortcutName
        Display Name of the shortcut.
    .PARAMETER ShortcutUrl
        URL associated with the shortcut.
    .PARAMETER ShortcutIconLocation
        Optional: Path to an icon to associate with the shortcut.
    .PARAMETER ShortcutOnDesktop
        Set to $true if the Shortcut needs to be added to the assigned User Profile Desktop.
    .PARAMETER ShortcutInStartMenu
        Set to $true if the Shortcut needs to be added to the assigned User Start Menu.
$BrowserPath = 'C:\Program Files (x86)\Google\Chrome\Application\chrome.exe'
$ShortcutName = "TSheets"
$ShortcutUrl = "https://app.tsheets.com/signin"
$ShortcutIconLocation = ""
$ShortcutOnDesktop = $true
$ShortcutInStartMenu = $true
$WScriptShell = New-Object -ComObject WScript.Shell
$CurrentUser = (Get-WmiObject -class win32_process -ComputerName 'localhost' | Where-Object name -Match explorer).getowner().user
if ($ShortcutOnDesktop) {
    $Shortcut = $WScriptShell.CreateShortcut("C:\Users\$CurrentUser\Desktop\$ShortcutName.lnk")
    $Shortcut.TargetPath = $BrowserPath
    $Shortcut.Arguments = $ShortcutUrl
    if ($ShortcutIconLocation) {
        $Shortcut.IconLocation = $ShortcutIconLocation
    $Shortcut.Save()
if ($ShortCutInStartMenu) {
    $Shortcut = $WScriptShell.CreateShortcut("C:\Users\$CurrentUser\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\$ShortcutName.lnk")
    $Shortcut.Save()
