What is a Worklet and how do I use or create one?
A worklet can accomplish any task that can be scripted.
The Automox platform is based on an open extensible automation architecture that allows IT operations to create any custom task that they can imagine. Automox consumes and automates worklets, powered by PowerShell and Bash scripting, and continuously enforces them across any managed devices. These reusable units of work can be shared with peers and applied across Windows, Linux, and OSX devices.
Because any code can be buggy or malicious, we review all Worklets submitted by the community before they go live. If you’d like to submit a Worklet, click on the New Topic button and post your code and instructions for use. Once your code has been reviewed by Automox we’ll make it live and let you know. To format your code, use the markup of 3 backticks (```) on the lines above and below your code. Then it will look like this:
Write-Host "Hello, World!"
For more details on what a Worklet is and what you can do with them, check out this page.
For instructions on how to create a Worklet, see this KB article:
