Week in Review - Release Notes for Week Ending 9/11/2020
https://support.automox.com/en/articles/4439217-week-in-review-release-notes-for-week-ending-09-11-2020
The new functionality to filter devices by Serial Number is also described here in our product documentation: https://docs.automox.com/home/devices/searching-sorting-and-filtering-device-information#device-info
If anyone is having problems getting the search by serial number to work, make sure you rescan your devices and then it should work properly. Also note that spaces in serial numbers (such as the ones generated by VMware) don’t work, but you can do partial matches like scanning for “VMware” and that should return all devices with a serial number including that string.
