Trigger Scan after Worklet
Hello all,
Is there a way to trigger a scan after a worklet or policy has been run?
For example using the worklet to update to the latest version of windows 10 is great, but you manually (or wait patiently for the scheduled scan) have to scan a device to get Automox to recognize the change.
Cheers,
Chris.
you could embed this worklet to the existing to start the scan when finished.
One thing to note is that after any patching policies run, a scan is automatically triggered, so you only need to worry about the worklet use case.
Hey @Nic, it should run a full scan after a Worklet policy runs as well. @it_stuck, Win10 feature upgrade is problematic as the Worklet’s end just after the upgrade starts. It runs it’s scan at this point rather than after the upgrade completion.
The best way I can think of to work around the way that works, is to add the script as a custom action script (I suggest Run Once to clean up the script after upgrade). This would only work on manageable versions of Win10 (pro, ent, edu).
https://docs.microsoft.com/en-us/windows-hardware/manufacture/desktop/windows-setup-enable-custom-actions
