Stop process
Hi!
I’m facing a lot of problems patching Chrome. If Chrome is running, then it won’t patch, and if user don’t close it in a lot of days the same. So at the end, it takes too much time for applying the patch.
I want to run a simple worklet to stop Chrome process:
EVALUATION
$chrome=Get-Process -Name "chrome" -ErrorAction SilentlyContinue
function checkChrome {
    if ($chrome.si -ne 0) {exit 1}
    else {exit 0}
checkChrome
REMEDIATION
Stop-Process -Name "chrome" -ErrorAction SilentlyContinue
Start-Process -FilePath "C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" -WorkingDirectory "C:\Program Files (x86)\Google\Chrome\Application"
As you see, it just checks if Chrome is running and then it stop the process and starts it. Doing this on localhost works, running from Automox nothing happends.
Any ideas?
Modified another worklet posted here to accomplish this - the hard part is getting it “touchless” so the user doesn’ t even know it updated. I’ve noticed in testing that the old flag chrome provided to auto-restore tabs does not work with the latest versions.
#Set the name of the application you want to affect
$process = “chrome”
#Check if $process is running. If it’s running, ask the user to close it, if it isn’t running then >exit quietly.
$process_running = Get-Process $process -ErrorAction SilentlyContinue
if ( !$process_running ) {
#If the process is not running then there’s nothing to do. Exit quietly.
Write-Host “$process was not running: nothing to close.” }
else {
#Play a sound with the pop-up message
[system.media.systemsounds]::Hand.play()
#Trigger the pop-up message with a Ok/Cancel option
[System.Reflection.Assembly]::LoadWithPartialName(‘System.Windows.Forms’)
$UserResponse = [System.Windows.Forms.MessageBox]::Show(“Google Chrome must be > updated on your system. Please save your work and click OK to close the application. IT” , > “Status” , 1)
#If user clicked OK, try to close the app gracefully
if ( $UserResponse -eq “OK” ) {
Write-Host “Closing $process application.”
$process_running.CloseMainWindow()
    ##Optional: Uncomment the stanza below to force kill the process after X seconds if >graceful exit failed
  Sleep 60
  if ( !$process_running.HasExited ) {
  	$process_running | Stop-Process -Force }
else
#If user clicked Cancel, exit and do nothing
Write-Host "Chrome update not applied: user chose to keep the app open."
Exit
Thanks for that! I’ll try and give you feedback :wink:
I’ve made some small changes. The main thing is that if we use “$process_running.CloseMainWindow()” when Chrome is restored, the tabs previously close are not. If we use “Stop-process -name $process” then it restores them.
Running it locally works, but when ran from Automox nothing happends, any idea??
$process = "chrome"
    Write-Host "$process was not running: nothing to close." }
	else {
    [System.Reflection.Assembly]::LoadWithPartialName('System.Windows.Forms')
    $UserResponse = [System.Windows.Forms.MessageBox]::Show("Para actualizar a la ultima version Chrome debe ser reiniciado. Guarda tu trabajo y haz click en OK para aplicar la actualizacion. Una vez cerrado, puedes iniciar Chrome de nuevo") #> "Status" 1)
    if ( $UserResponse -eq "OK" ) {
	Stop-process -Name $process -ErrorAction SilentlyContinue
Although a worklet is great… I’d advise you to look into Google Chrome Browser Management which handles updates very well.
