HI Team,
Looking at the documentation for SAML SSO, it says if SAML enabled it disables 2FA.
Is it possible to re-enable 2FA after SAML completed, or is it one or the other?
Cheers,
Chris.
HI Team,
Cheers,
Chris.
From the testing I did you will not be able to use Automox’s 2FA once SAML SSO is enabled.
But that doesn’t mean you need to skip 2FA. We leveraged the 2FA on the SSO provider side (Azure AD) so that we can use SSO and 2FA to connect to Automox.
That’s correct - if you’re using SAML then you should be using the 2FA of your identity provider rather than our 2FA.
