Service Checker script issues.
I have been having issues with a script I found and even after modifying it I am unable to make it work. Could someone take a look and see if there’s an issue that I’m missing?
The idea is to get the services before, then after a reboot. It works fine when running as system in powershell ise so I’m unsure what issue I’m running into.
I will say this is running on 2012r2 via the automox agent under remediation with exit 1.
Check Script: Exit 1
Remediation Script:
Write-Output "Beginning Scan"
[string]$myorg = "Org1"
[string]$groupname = "Group_01"
$myorg      = "Org1"
$groupname  = "Patching_Group_01"
[string]$ComputerName = "localhost"
[string]$Search = "zzzz"
[string]$Search2 = "zzzz"
$DirPath = "C:\temp\AmoxPatching\$myorg\$groupname\Services"
$DirPathCheck = Test-Path -Path $DirPath
If (!($DirPathCheck)) {
    Try {
        #If not present then create the dir
        New-Item -ItemType Directory $DirPath -Force
    Catch {
        Write-Output "The Directory $DirPath was not created."
Set-Location -Path "C:\temp\AmoxPatching\$myorg\$groupname\Services"
$Final = @()
$hosts = $ComputerName
Foreach ($Computer in $hosts) {
    $XmlNameBefore = "$Computer" + "-Before" + ".xml"
    if ($ComputerName) {
        $XmlNameAfter = "$Computer" + "-After" + ".Individual" + ".xml"
    else {
        $XmlNameAfter = "$Computer" + "-After" + ".xml"
    if (!(Test-Path .\$XmlNameBefore)) {
        Write-Host "(BEFORE)" -ForegroundColor Green -NoNewline
        Write-Host " Connecting to $Computer..." -NoNewline
        try {
            get-wmiobject win32_service -ErrorAction Ignore | select SystemName, Name, DisplayName, State, StartMode | sort StartMode | Export-Clixml .\$XmlNameBefore
            if ($?) { Write-Host "Success" -ForegroundColor Green }
            else {
                Write-Host "WMI connection failed" -ForegroundColor Red
                Remove-Item .\$XmlNameBefore -recurse
        Catch {
            Write-Host "Access Denied" -ForegroundColor Red
    elseif ((Test-Path .\$XmlNameBefore) -and !(Test-Path .\$XmlNameAfter)) {
        Write-Host "(AFTER)" -ForegroundColor Yellow -NoNewline
        try {
            get-wmiobject win32_service -ErrorAction Ignore | select SystemName, Name, DisplayName, State, StartMode | sort StartMode | Export-Clixml .\$XmlNameAfter
            else {
                Write-Host "FAILED" -ForegroundColor Red
                Remove-Item .\$XmlNameAfter -recurse
        Catch {
    if ((Test-Path .\$XmlNameBefore) -and (Test-Path .\$XmlNameAfter)) {
        $wmi = Get-WmiObject -Class Win32_OperatingSystem -Computer $Computer
        $RebootTime = $wmi.ConvertToDateTime($wmi.LastBootUpTime)
        $RebootTime = $RebootTime.ToLocalTime()
        $RebootDiff = ((get-date) - $RebootTime)
        $RebootDiffHours = [math]::round($RebootDiff.totalHours, 1)
        $RebootDiffDays = [math]::round($RebootDiff.totalDays, 1)
        $XmlNameBeforeTIME = (Get-ChildItem .\$XmlNameBefore).LastWriteTime
        $XmlNameAfterTIME = (Get-ChildItem .\$XmlNameAfter).LastWriteTime
        [PsObject]$xmlBefore = Import-Clixml -Path ".\$XmlNameBefore"
        [PsObject]$xmlAfter = Import-Clixml -Path ".\$XmlNameAfter"
        $CompareBefore = @()
        $CompareAfter = @()
        $CompareBefore = Compare-Object $xmlBefore $xmlAfter -Property SystemName, Name, DisplayName, State, StartMode | where { $_.SideIndicator -EQ "<=" }
        $CompareAfter = Compare-Object $xmlBefore $xmlAfter -Property SystemName, Name, DisplayName, State, StartMode | where { $_.SideIndicator -EQ "=>" }
        if ((!$CompareBefore) -and (!$CompareAfter)) { Write-Host "► No differences found for $Computer ◄" -ForegroundColor Yellow }
        $obj = @()
        $obj += ForEach ($line1 in $xmlBefore) {
            # Looking for all rows in the first CSV file
            ForEach ($line2 in $xmlAfter) {
                # Looking for all rows in the second CSV file
                if ($line1.name -eq $line2.name) {
                    # If the same service name is found in both files
                    if (($line1.startmode -ne $line2.startmode) -or ($line1.state -ne $line2.state)) {
                        # If different
                        New-Object -TypeName PSObject -Property @{
                            SystemName       = $line1.SystemName
                            Rebooted_Hrs     = $RebootDiffHours
                            Name             = $line1.name
                            DisplayName      = $line1.DisplayName
                            StartMode_Before = $line1.startmode
                            StartMode_After  = $line2.startmode
                            State_Before     = $line1.state
                            State_After      = $line2.state
        } #end of Foreach
        foreach ($line1a in $CompareAfter) {
            $found = $false
            foreach ($line1b in $CompareBefore) {
                If ($line1b.DisplayName -eq $line1a.DisplayName) {
                    $found = $true
            if ($found -eq $false) {
                $obj += New-Object -TypeName PSObject -Property @{
                    SystemName       = $line1a.SystemName
                    Name             = $line1a.name
                    DisplayName      = $line1a.DisplayName
                    StartMode_After  = $line1a.startmode
                    State_After      = $line1a.state
                    StartMode_Before = '---'
                    State_Before     = '---'
            $found = $false
                If ($line1a.DisplayName -eq $line1b.DisplayName) {
                    $found = $true
                    SystemName       = $line1b.SystemName
                    Name             = $line1b.name
                    DisplayName      = $line1b.DisplayName
                    StartMode_Before = $line1b.startmode
                    State_Before     = $line1b.state
                    StartMode_After  = '---'
                    State_After      = '---'
        $Final += $Obj
    } # End of If Test-path
} # End of Foreach $Computer
$Final2 = @()
$Final2 = $Final | sort DisplayName | Select SystemName, Rebooted_Hrs, Name, State_Before, State_After, StartMode_Before, StartMode_After, DisplayName
if ($Final2) {
    If ($ComputerName) {
        if (Test-Path "$($ComputerName).$($myOrg).$($PatchGroup).Report.$(Get-date -f 'yyyy.MM.dd_HH.mm.ss').html") {
            remove-item "$($ComputerName).$($myOrg).$($PatchGroup).Report.$(Get-date -f 'yyyy.MM.dd_HH.mm.ss').html"
    else {
        If (Test-Path "$($myOrg).$($PatchGroup).Report.$(Get-date -f 'yyyy.MM.dd_HH.mm.ss').html") {
            Remove-item "$($myOrg).$($PatchGroup).Report.$(Get-date -f 'yyyy.MM.dd_HH.mm.ss').html"
    $head = @'
<Title>Service Compare</Title>
<style>
body
    background-color:#FFFFFF;
    font-family:Tahoma;
    font-size:12pt;
td, th
    border:1px solid black;
    border-collapse:collapse;
th
    color:white;
    background-color:black;
table, tr, td, th { padding: 5px; margin: 0px; box-shadow: 2px 2px 1px #888}
table { margin-left:50px; }
.danger {background-color: red}
.warn {background-color: yellow}
</style>
    #create an xml document from the HTML fragment
    [xml]$html = $Final2 | ConvertTo-Html -fragment
    #check each row, skipping the TH header row
    for ($i = 1; $i -le $html.table.tr.count - 1; $i++) {
        $class = $html.CreateAttribute("class")
        #check the value of the last column and assign a class to the row
        if (($html.table.tr[$i].td[7]) -like "*$Search*") {
            $class.value = "warn"
            $html.table.tr[$i].Attributes.Append($class) | Out-Null
        elseif (($html.table.tr[$i].td[7]) -like "*$Search2*") {
            $class.value = "danger"
    #create the final report from the innerxml which should be html code
    $body = @"
<p style="LINE-HEIGHT:10px;margin-left: 60px"><b>BEFORE</b> data was collected on $XmlNameBeforeTIME</p>
<p style="LINE-HEIGHT:0px;margin-left: 60px"><b>AFTER</b> data was collected on $XmlNameAfterTIME</p>
$($html.innerxml)
    #put it all together
        ConvertTo-HTML -head $head  -PostContent "<br><i>HTML Generated on $(get-date)</i>" -body $body | Out-File "$($ComputerName).$($myOrg).$($PatchGroup).Report.$(Get-date -f 'yyyy.MM.dd_HH.mm.ss').html" -Encoding ascii
    else {
        ConvertTo-HTML -head $head  -PostContent "<br><i>HTML Generated on $(get-date)</i>" -body $body | Out-File "$($myOrg).$($PatchGroup).Report.$(Get-date -f 'yyyy.MM.dd_HH.mm.ss').html" -Encoding ascii
    #$ReportPath = (Get-Item -Path ".\Report.html" -Verbose).FullName
    #Invoke-Item $ReportPath
#else {
#    if (!$Final) {write-host `n "No differences found" -ForegroundColor Yellow}
Hello driosk!
This may sound very strange, but sometimes things get funky with the " double quotes when Automox executes Powershell. I was able to get your script to work through a worklet by replacing all double quotes " with single quotes '.
Please give this a shot and let me know if the script still isn’t executing via Automox worklet.
Thanks!
Yep, that’s what it was. I was able to get it running, after brushing back up on my single quoting, it’ll need some more work to get up and running the way I want but this will do for now. Thank you.
Here’s the script, it needs some editing but it’ll probably get put into a public repo soon enough. ^_~
[string]$myorg = 'Org1'
[string]$groupname = 'Group_01'
#Single quote run
$myorg      = 'Org1'
$groupname  = 'Patching_Group_01'
[string]$ComputerName = $env:COMPUTERNAME
[string]$Search = 'zzzz'
[string]$Search2 = 'zzzz'
$DirPath = 'C:\temp\AmoxPatching\' + $myorg + '\' + $groupname + '\Services'
    Try {
    Catch {
        Write-Output 'The Directory $DirPath was not created.'
Set-Location -Path $DirPath
$Final = @()
    $XmlNameBefore = $Computer + '-Before' + '.xml'
        $XmlNameAfter = $Computer + '-After' + '.Individual' + '.xml'
    else {
        $XmlNameAfter = $Computer + '-After' + '.xml'
    if (!(Test-Path $XmlNameBefore)) {
        Write-Host '(BEFORE)' -ForegroundColor Green -NoNewline
        Write-Host ' Connecting to'$Computer'...' -NoNewline
        try {
            get-wmiobject win32_service -ErrorAction Ignore | select SystemName, Name, DisplayName, State, StartMode | sort StartMode | Export-Clixml $XmlNameBefore
            if ($?) { Write-Host 'Success' -ForegroundColor Green }
            else {
                Write-Host 'WMI connection failed' -ForegroundColor Red
                Remove-Item $XmlNameBefore -recurse
        Catch {
            Write-Host 'Access Denied' -ForegroundColor Red
    elseif ((Test-Path $XmlNameBefore) -and !(Test-Path $XmlNameAfter)) {
        Write-Host '(AFTER)' -ForegroundColor Yellow -NoNewline
        try {
            get-wmiobject win32_service -ErrorAction Ignore | select SystemName, Name, DisplayName, State, StartMode | sort StartMode | Export-Clixml $XmlNameAfter
            else {
                Write-Host 'FAILED' -ForegroundColor Red
                Remove-Item $XmlNameAfter -recurse
        Catch {
    if ((Test-Path $XmlNameBefore) -and (Test-Path $XmlNameAfter)) {
        $XmlNameBeforeTIME = (Get-ChildItem $XmlNameBefore).LastWriteTime
        $XmlNameAfterTIME = (Get-ChildItem $XmlNameAfter).LastWriteTime
        [PsObject]$xmlBefore = Import-Clixml -Path $XmlNameBefore
        [PsObject]$xmlAfter = Import-Clixml -Path $XmlNameAfter
        $CompareAfter = @()
        $CompareBefore = Compare-Object $xmlBefore $xmlAfter -Property SystemName, Name, DisplayName, State, StartMode | where { $_.SideIndicator -EQ '<=' }
        $CompareAfter = Compare-Object $xmlBefore $xmlAfter -Property SystemName, Name, DisplayName, State, StartMode | where { $_.SideIndicator -EQ '=>' }
        if ((!$CompareBefore) -and (!$CompareAfter)) { Write-Host '► No differences found for $Computer ◄' -ForegroundColor Yellow }
        $obj = @()
                        # If different
                            Name             = $line1.name
        } #end of Foreach
            $found = $false
                    $found = $true
                    Name             = $line1a.name
            $found = $false
                    $found = $true
                    Name             = $line1b.name
                    State_After      = '---'
        $Final += $Obj
$Final2 = @()
if ($Final2) {
        $SingleHostReportPath = $ComputerName + '.' + $myOrg + '.' + $groupname + '.Report.' + (Get-date -f 'yyyy.MM.dd_HH.mm.ss') + '.html'
        if (Test-Path $SingleHostReportPath) {
            remove-item $SingleHostReportPath
    else {
        $MultipleHostPath = $myOrg + '.' + $groupname + '.Report.' + (Get-date -f 'yyyy.MM.dd_HH.mm.ss') + '.html'
        If (Test-Path $MultipleHostPath) {
            Remove-item $MultipleHostPath
    $head = @'
<style>
body
    font-family:Tahoma;
    font-size:12pt;
td, th
th
    color:white;
</style>
        $class = $html.CreateAttribute('class')
        if (($html.table.tr[$i].td[7]) -like '*'+$Search+'*') {
            $class.value = 'warn'
        elseif (($html.table.tr[$i].td[7]) -like '*'+$Search2+'*') {
            $class.value = 'danger'
    $body = @"
<p style='LINE-HEIGHT:10px;margin-left: 60px'><b>BEFORE</b> data was collected on $XmlNameBeforeTIME</p>
<p style='LINE-HEIGHT:0px;margin-left: 60px'><b>AFTER</b> data was collected on $XmlNameAfterTIME</p>
$($html.innerxml)
        ConvertTo-HTML -head $head  -PostContent '<br><i>HTML Generated on'(Get-Date).ToString()'</i>' -body $body | Out-File $SingleHostReportPath -Encoding ascii
    else {
        ConvertTo-HTML -head $head  -PostContent '<br><i>HTML Generated on'(Get-Date).ToString()'</i>' -body $body | Out-File $MultipleHostPath -Encoding ascii
    #$ReportPath = (Get-Item -Path '.\Report.html' -Verbose).FullName
#else {
#    if (!$Final) {write-host `n 'No differences found' -ForegroundColor Yellow}
