Script to Remove AlienVault Agent
Hello Automoxville,
I was wondering if any of you wonderful people have tried to uninstall the AlienVault agent with Automox?
We just switched to a different SIEM vendor and AlienVault’s documentation for uninstalling the agent via script is not very helpful.
https://cybersecurity.att.com/documentation/usm-anywhere/agents/agent-script.htm?Highlight=uninstall%20agent
Any assistance would be greatly appreciated.
Have you tried referencing our macOS app uninstall worklet in the community?
https://community.automox.com/t/worklet-uninstalling-applications-on-macos
@dmunson, I haven’t tried it, but along with @Tony’s help, we may be able to provide some guidance. What OS are you working to uninstall AlienVault Agent from?
Linux (Ubuntu 18.04).
Alienvault’s documentation says to run the alienvault-agent.sh file located in /usr/bin for Linux. So my worklet I wrote is this:
cd /usr/bin/
alienvault-agent.sh uninstall
But that doesn’t seem to be doing it…
You should just put the full path to the uninstall script, rather than changing directories in the script. So:
/usr/bin/alienvault-agent.sh uninstall
