Modify registry key/value under HKEY_USERS (HKCU Workaround)
Hey guys,
It has come up a few times that modifying HKCU in a worklet doesn’t behave as expected. This is because the process is running under the SYSTEM account. So only the keys under the SYSTEM SID (S-1-5-18 ) will be modified if you point to HKCU:\.
This evaluates and sets the desired value for every local user account tied to that device:
Evaluation
#Define desired registry settings
$regPath = "Key Path Here"
$regName = "Property/Value Name Here"
$desiredValue = "I'm a String"
#Get User details including SID from Get-LocalUser
$users = Get-WmiObject -Class Win32_UserAccount -Filter "LocalAccount = 'True'"
#Add HKEY_USERS to a PSDrive for easy access later
New-PSDrive -PSProvider Registry -Name HKU -Root HKEY_USERS -ErrorAction SilentlyContinue | Out-Null
$nonCompliant = @()
#Loop through the list of users to check each for compliance
foreach ($user in $users) {
    #Retrieve SIDs for each user
    $sid = $user.SID
    $name = $user.Name
    #Load Registries for users, if ntuser.dat exists
    #this prevents us from attempting to load Administrator and similar accounts
    if (Test-Path "C:\Users\$name\ntuser.dat") {
        #Load user's ntuser.dat into the registry
        & reg load "HKU\$sid" "C:\Users\$name\ntuser.dat" | Out-Null
        $properties = Get-ItemProperty -Path "HKU:\$sid\$regpath"
        $value = $($properties.$regName)
        #If this value doesn't match the desired value, add the user name to nonCompliant list
        if ($value -ne $desiredValue) {
            $nonCompliant += $name
#Clean-up the PSDrive
Remove-PSDrive -Name HKU
#If any users are non-compliant, "Exit 1" to flag remediation. Else "Exit 0" for Compliant
if ($nonCompliant.Count -gt 0) {
    Exit 1
} else { Exit 0}
Remediation
$propertyType = 'Binary'
    $sid = $user.SID
    $name = $user.Name
        #Create Key
        New-Item -Path "HKU:\$sid\$regPath" -ItemType Directory -Force
        #Create Value
        New-ItemProperty -Path "HKU:\$sid\$regPath" -Name $regName -PropertyType $propertyType -Value $desiredValue
Try this.
Also, here’s another example that doesn’t use GMI to enumerate users.
