Intune or WSUS?
Hi. I was wondering if anyone is using automox with Intune to deploy patches or using the WSUS integration?
We currently are using WSUS here
I don’t believe we have a direct integration with Intune like we do with WSUS. Are you using Intune to roll out Automox agents?
We are, We also use Microsoft Defender, which pulls in patches as well and offers the option to remediate in the defender panel, but that is tied to intune, which is why I was asking.
Unfortunately no plans to do an Intune integration (not sure how that would work anyway, since they’re a competitor with us). You might be able to find a way to pull data in and out using the API if you need to use Intune as the place of record and for reporting.
