How to monitor if a Certain Software is Installed on All Devices
Hello Automox Community!
After using 2 years SCCM, I have switched to Automox two months ago. So far I cannot find an adequate way to monitor the progress of an application’s rollout. Does I can’t see which devices failed to update certain application to the latest version or completely missing the app.
I have tried this script - Use API to Determine if a Certain Software is Installed on All Devices but does not generate in the report information in the columns for application name and version. Only generates the names of all our devices.
Could you please advise what is the best way to monitor the progress of rollout of application or to get in a report the name and the version of particular software on all devices?
Thank you in advance :slight_smile:
