Force password reset?
How difficult would it be to create a worklet to force a password reset on Windows 10 Pro PCs?
That should be doable as long as there’s a powershell command or registry setting we can set. I’ll do some research and see what I find out. If anyone else knows the answer feel free to point me in the right direction!
From some initial poking around it looks like it’s possible:
I’m assuming your use case is for local user accounts that aren’t in AD?
Yes, we are running without AD or an AD domain.
I’ve looked into Jumpstart for managing our PCs, but it seems like so much can be done with Worklets that we can get along with them for the few administrative things we want to do (enforce minimum password security, locked screen savers, etc.)
^JumpCloud
Sounds good. We’re working on creating a bunch of new Worklets so I’ll add this to our list to work on for you.
Thanks!
Sorry for the delay - I finally got some time to work on this and wrote up a worklet here:
Let me know if that works for you!
