Hello,
I am wondering if it’s possible to deploy the Automox Agent to an EC2 Linux instance in AWS? I know the agent works with normal Linux, but I’m not sure about the EC2 instance. Any suggestions?
Thanks!
Hello,
Thanks!
Absolutely! So long as the type of instance is a supported type that meets the resource requirements, it will work for you. If you meant Amazon linux specifically, that’s a yes!
