Check local group membership then add user if not present
What am I doing wrong here? This doesn’t seem to be working and I can’t seem to figure out why. Thanks all.
Eval Code
$user = ‘DomainNameHere\DomainGroupHere’
$LocalGroup = ‘Administrators’
if ((Get-LocalGroupMember -Group $LocalGroup).Name -contains $user)) {
} else { Exit 1 }
Remediation Code
Add-LocalGroupMember -Group $LocalGroup -Member $user
The Microsoft.PowerShell.LocalAccounts module is not available in 32-bit PowerShell on a 64-bit system.
If you move your code into a scriptblock like this, it will allow you to use that module via Worklet:
# REQUIRES -Version 2.0
#Handle Exit Codes:
trap {  $host.ui.WriteErrorLine($_.Exception); exit 90 }
$scriptblock = {
    YOUR_CODE_GOES_HERE
$runScriptBlock = & "$env:SystemRoot\sysnative\WindowsPowerShell\v1.0\powershell.exe" -ExecutionPolicy Bypass -WindowStyle Hidden -NoProfile -NonInteractive -Command $scriptblock
