Bitlocker Key ID and Recovery Key
Been working on a worklet policy to grab bitlocker keys ID and recovery keys.
So far I’ve been successful at making the policy create a .csv locally to the machine.
Not sure if this is the best place to post this, but if anyone wants to expand on this such as.
a) out-putting to FTP server, URL, etc. please do
$KeyProperties = @()
$KeyObj = @()
$Computer = $env:Computername
$Keys = Get-BitlockerVolume -MountPoint C:
$selected = $Keys | Select-Object -ExpandProperty KeyProtector
$Selected[1] | select-Object KeyprotectorID, RecoveryPassword
Foreach ($S in $Selected) {
    $KeyProperties = [pscustomobject]@{
            Computer = $Computer
            KeyProtectorID = $S.KeyProtectorID
            RecoveryPassword = $S.RecoveryPassword
    $KeyObj += $KeyProperties
$KeyObj[1] | Export-CSV "C:\$($Computer)_Keys.csv" -NoTypeInformation
Thanks for sharing @cfrieberg! I added in the code block formatting to your post - let me know if that looks like it kept the right indenting. For the code blocks, you just have to put ``` on the line above and below the code.
thanks Nic!
testing testing 123
Oh look at that.
The code block feature is pretty nice. Not only does it preserve formatting, but it autodetects what programming language you are using and does color labels accordingly.
Yea, that’s pretty slick!
Thanks for sharing! This is awesome and something I’ve seen a lot of people ask for.
Wasn’t sure how to edit my original post.
Just following up since I noticed output from this worklet also being stored in Automox Activity Log.
Interesting.
If you click the little pencil icon in the bottom left of your post you can edit it.
It’ll store in the log whatever message you return in the code. That does make it easier to have in one place to collect than gathering a bunch of CSV files from each endpoint.
I’m blind…
It might be because I have the permissions locked down on submitting posts to the Worklet section - they have to get approved so that we can review the code first. Normally it will let you edit your post, but in this case it would let someone replace the code the originally posted with something potentially malicious or broken. Just send me your edits and I can replace the code for you.
How was this implemented into the existing bit locker script that Automox has provided on these forums? Did you just add it into the Remediation code?
Yes - added to rc
