Let’s get the party started!
Userlevel 3
Do we have a worklet that’ll remove all versions of Adobe Flash 😛
This will take care of the standalone, but the browser embedded ones might be trickier. I’ll have to do some digging to see if that’s feasible.
Userlevel 3
That’s fine.
MS have an update that removes that side of it, which will be rolled into cumulative update shortly.
Thanks!
Login to the community
