get-automox.yml kb and playbook corrections
  • 18 May 2022
  • 141 views
In the automox kb the ansible playbook is broken and I wanted to submit my corrections- https://support.automox.com/help/deploying-the-automox-agent-in-bulk:
Deploying with Ansible
You can distribute the Automox agent with Ansible using the Ansible playbook: get-automox.yml. Contact Automox Support for further assistance.
From the directory where the ‘get-automox.yml’ file is located, invoke the playbook with the following command, substituting your unique user key (zone key) as indicated:
ansible-playbook get-automox.yml --extra-vars "zone=YOUR-ZONE-KEY-HERE
In get-automox.yml:
    - name: Ensure amagent is enabled and started
      service:
        state: running <- Causes the playbook to fail.
        enabled: yes
state: running is not a valid state.
Changing it to state: started fixes the problem.
Also, the command fails: ansible-playbook get-automox.yml --extra-vars "zone=YOUR-ZONE-KEY-HERE
Changing the command to
ansible-playbook -i hosts get-automox.yml --extra-vars “organization=ZONE_KEY”
The variable zone does not exist, I think it may have been updated but the documentation doesn’t reflect the change.  Also the command is missing a trailing double quote.
In get-automox.yml:
  vars:
    automox_url: https://console.automox.com/downloadInstaller?accesskey={{ organization }} <- variable name is not zone
The organization variable is where the zone variable would be.
# Ansible playbook to install Automox Agent on Linux-based system
# Execute with following command (provide your organization key):
# ansible-playbook get-automox.yml --extra-vars "organization=your-organization-key-here"
- hosts: all
become: true
become_method: sudo
remote_user: root
vars:
automox_temp_dir: /tmp/automox_install
automox_temp_dir_mode: 0700
automox_temp_install_file: install.sh
automox_install_script_owner: root
automox_install_script_group: root
automox_install_script_mode: 0700
tasks:
- name: Ensure temp directory exists
file:
path: "{{ automox_temp_dir }}"
state: directory
owner: "{{ automox_install_script_owner }}"
group: "{{ automox_install_script_group }}"
mode: "{{ automox_temp_dir_mode }}"
- name: Download Automox Agent from automox_url
get_url:
url: "{{ automox_url }}"
dest: "{{ automox_temp_dir }}/{{ automox_temp_install_file }}"
mode: "{{ automox_install_script_mode }}"
- name: Execute Automox install script
command: "./{{ automox_temp_install_file }}"
args:
chdir: "{{ automox_temp_dir }}"
notify:
- restart Automox
service:
state: started
enabled: yes
handlers:
- name: restart Automox
service:
state: restarted
This is copypasta of my updated playbook :)
