Automox solution for pushing .mobileconfig files on Mac?
  • 28 September 2022
  • 2 replies
  • 83 views
Does anyone know of an Automox solution for installing .mobileconfig files on a Mac? I’ve been doing some digging on how to remotely push our CIS profiles (without using JAMF or some other sort of MDM) but have not had any luck. Thanks in advance!
Hey Michael,
It is not possible to install a .mobileconfig profile with Automox at this time, Apple only allows this to be done via an MDM.
However, you may be able to attach the Profile to a Worklet, then use the “mv” or “cp” command to move the profile to the Desktop so the user can install it themselves.
Thank you.
Great idea! Thank you. I’ve got quite a few profiles to install so that should work great. Thanks again!
