o365 business worklet
  • 9 October 2019
  • 25 views
Hi All,
Im struggling abit to get a worklet working correctly for both mac and windows. No need for applying a licence as all users are individually licenced upon login.
Can any one share your wisdom with this one? spent the last few hours on forums and seems like an easy one for jamf and munki but not here.
Userlevel 7
Happy to help! If it’s working in jamf and munki, it might be a wrinkle with the runtime environment when it runs as a worklet. The worklet code runs as system and in a specific directory.
If you want to post the code here I’d be happy to take a look and try to get it running. For posting code to the community, put three backticks (`) on the lines above and below the code blocks and that will apply the code formatting and color coding to the code block.
