Solved
Intune Deployment
  • 5 April 2022
  • 2 replies
  • 2545 views
Userlevel 2
I am using this install command on intune and I tested the same command in a brand new machine.
It did install, but it is not registering the machine on automox console.
Install command
msiexec /i "Automox_Installer-1.0.34.msi" /qn /norestart ACCESSKEY=XXXXXXXXXXXXXX="Default"
Uninstall command
msiexec /x "{XXXXXXXXXXXXXXXX}" /qn
XX is replacing our zone code.
2 issue, for all other machines added, I am getting these 2 errors.
Error unzipping downloaded content. (0x87D30067)
The unmonitored process is in progress, however it may timeout. (0x87D300C9)
Conclusion
The first command msiexec etc - is not correct, so what I am missing?
icon
Best answer by Afonso_Alves_31 12 April 2022, 13:19
View original
Userlevel 5
Badge +1
If you can run a script from Intune, check out https://patch.automox.com/rs/923-VQX-349/images/Install-AxAgentMsi.ps1
I think the use of ="Default" is not needed. Perhaps try
msiexec.exe /i Automox_Installer-1.0.37.msi ACCESSKEY=Your-Access-Key /qn /norestart
Userlevel 2
The best way for implementing the app was to use the “Windows MSI line-of-business app” instead of using the intune tool win32 app.
It did work well with the argument
