Enforce Scheduled Reboot on Machines
  • 31 July 2020
  • 4 replies
  • 691 views
Userlevel 2
Userlevel 7
Userlevel 2
Hi Nic,
Userlevel 7
Sounds good - then the above worklets should do what you are needing then!
The above links are no longer active.  Can you please repost with new URLs to the article?
