Add API PATCH method to Device Tags
  • 13 October 2021
  • 2 replies
  • 110 views
Userlevel 2
Right now, we can edit device tags, but in order to keep from overwriting current valuable device tags, we need run a GET command, save all device tag content into an array, and then execute a PUT command to write an entirely new batch of tags.
It would be way easier if we could just run a PATCH command as an additive operation add more new tags.
This is a particular pain point when we have scripts creating from-scratch tags for devices that end up overwriting valuable manually-created tags that some of our technicians have added for their own records.
Userlevel 3
Patch would be nice, but its not to hard to pull the existing tags from a device and then add them to the list of tags you want to set. See this post, the end has a nice example. Read past the first part to see the code for additive.
Userlevel 2
Thanks @David_Mitchell . I should clarify the reason we want this feature so badly is because we’re making api calls from our linux clients via bash. (Keeping things in bash makes a lot of our other linux endpoint work easier). If I were using powershell, python, or a more modern language, the need wouldn’t be so high.
