The scripts posted in here go live immediately, unlike the worklets which are reviewed first. They still get reviewed after posting to make sure the code works and isn’t malicious, but there’s a bit more caveat emptor in here since scripts require more technical knowhow to run.
To share a script, click on the New Topic button and post your code and instructions for use. To format your code, use the markup of 3 backticks (```) on the lines above and below your code. Then it will look like this:
Write-Host "Hello, World!"
For more details on how to get started with script writing, check out this guide:
https://support.automox.com/help/newbies-guide-to-getting-started-with-automox-api
